- Jan 21, 2003
- 53
- 0
- 0
I recently upgraded to XP for obvious reasons and it has been working fine, except for one aspect. I have not been able to play DVD's properly with my original Teac 8X drive. I wasn't able to find/don't have the original install disk for the Intervideo WinDVD that came with the drive so I installed Cyberlink PowerDVD that I had from the drive in my desktop. *shh, don't tell*. It seemed to install properly and accept the key so I figured all was a go. I tried to play a DVD straight from the drive and experienced stuttering in playback, bad skipping/stuttering w/e you want to call it. It was worse in high sound or high motion situations. I thought that it might be the drive so I ripped the DVD *shh* to the hard drive and had the same problems. I also tried to play the DVD with WMP 10 using the PowerDVD decoder and all I could ever get was errors. Even after reinstall and second attempt. Has anyone experienced this or have a soluton. Or is there a free decoder or player out there that I could try?
I have an older Gateway Solo 5300 with a 750Mhz Pentium III, Teac 8x DVD drive, XP Pro, PowerDVD V 4.0, S3 Graphics Savage/IX, 256 MB ram, everything has updated drivers.
Thanks for all your help, I really want to be able to play DVDs on a 24 hr bus ride
