Where is my power light?
dmw16
7,608
I have an Enlight 7237 and from day one my power light never came on. My HDD activity light is fine, but the power light isnt. Any ideas what is wrong here?
thanks,
-doug
junthin
4,132
Did you get the power header plugged in correctly on the motherboard? The White Wire should be you're ground wire. Double check with your Motherboard Manual.
If that's not it, then I'd suggest rewiring a LED on it. ;)
