- May 6, 2015
- 390
- 35
- 61
It's X58, it's not quite comparable to Core i7 Nehalem as it's 32nm and has a way larger L3 cache of 12mb, and it has a superior memory controller.
These CPU's if you have the board can go further than 4.2ghz, i'm at 4.2 on just 1.3v which is low voltage for 32nm.
Some notes i am using GTX 670 in PCI-E 1 to extend screens, and the numbers for core speed are not correct in Cinebench, i have C states enabled so the CPU does spool up and down also.
Interestingly single core performance at 4.2 beats the FX 8 core at 5ghz.
