Where can I get heat sinks for a Prophet II MX card? I have it overclocked to 205 Core, 215 Mem. I had it at 215/225 but I got errors on the screen. 202/215 seems perfectly stable. I think if I get a heat sink I can possible go higher.
Get the Gorb and use the old Heat sink and make yourself 4 Ram sinks with a hacksaw and file (this is what I did and I used the frag tape from The Gorb to secure the home made Ram sinks to the Ram) - you save $20 this way.
