Where can I get a THIN case?
grooves12
Are there any extremely thin cases available to use when you have a system with a completely integrated chipset (such as nForce) that doesn't requre the use aof any expansion cards?? Size and Aesthetics are the main things to be considered... what are my options?
mechBgon
Oct 31, 1999
30,699
There sure is. Here you go, a 2U rackmount case. :)
Other than that, maybe you would consider a FlexATX "BookPC"-style case, but it sure won't take an ATX motherboard, and I don't know of any flexATX nForce on the market yet. You can find some good photos of various cases at www.directron.com to help with your brainstorming.
