ahurtt, you are correct...
I am looking for a rear bracket (NOT a PCI Card) that goes into 1 of the 7 expansion bays on the back of a case. It then plugs into the headers on your motherboard. I need one that has 2 USB 2.0 plugs, and 1 1394a (FireWire) plug. I have only found one of these (on Intel's shop websire), but it wasn't 2.0 compatible. My motherboard manufacturer doesn't make the one with 2 USB and 1 1394... and THAT is the one I want. Does anyone know where to get a bracket like this? It may be referred to as a Bracket, Backplate, Rear Panel, etc...
-Thanks
