Where can I find a 15' power cable?
Kaido
Feb 14, 2004
51,539
7,230
Any ideas? Not even getting much luck on ebay...
Kaido
Feb 14, 2004
51,539
7,230
Originally posted by: JonnyBlaze
extension cord?
I'd prefer a normal power cable. I'm hooking a projector into the ceiling with a mount, then I want to run the power and video cables into a Wiremold raceway (wire covers for wall mounting) to the A/V equipment. The raceway is only thick enough to hold wires, not plugs, which would mean that a normal extension cable wouldn't fit because the plug on the prongs would be too big. I might just skip the raceway on the ceiling though, I'm not sure yet.
oynaz
2,449
Or you could just ask the closest electrician to make one for you.
