sharkeeper
Matrox Parhelia is supposed to be 512 bits. We all know it has/had sub Ti4600 performance where it counts.
What about ATi/nVidia? Anyone know?
-DAK-
-DAK-
Exactly. A 512-bit memory path may help performance if the GPU can take advantage of it, but "512-bitness" by itself is meaningless. It might make more sense to keep 256-bit and just up the memory clock more, or have ultrafast cache memory, or onboard SLI with 2 GPUs and 2 memory pools, or ....?
Interesting question -- I suppose one easy way to guess about whether a GPU is processor-limited or bandwidth-limited to to play with the clocking for each with an overclocking tool. Underclock the memory and see if franerates drop, overclock and see if they rise, and do the same with the GPU core speed while holding the memory clock constant.Is it possible (outside of the environment of manufacturing) to gauge GPU load? Sort of like a GPU task manager? Perhaps a form of HT for GPU's could help things out.
I wonder if Dual Channel video cards will ever make their way into the market because if you think about it, video cards today have things many motherboards didn't have years ago. DOing that would allow them to use older RAM modules while maintaining speed and cutting costs of more expensive RAM allowing them to focus more on the GPU itself rather than memory...
The Matrox Parhelia was and is a 512bit GPU, however it had sub Ti4200 performance because they didnt clock it very high, didnt include any memory optimisations and had a lack of any type of compression.Originally posted by: shuttleteam
-DAK-
-DAK-
Originally posted by: Pete
Did you even read this thread, vc? Sure, some enterprising guy or gal in marketing will slap the term "1024 bit" on an upcoming GPU, but that'll be as meaningless as Apple's classification of their G4 and G5 towers as "supercomputers."
