When will the 5TB drives come out?
Discussion in 'Memory and Storage' started by titanmiller, May 10, 2012.
  1. LOL_Wut_Axel
    LOL_Wut_Axel Diamond Member
    Mar 26, 2011
    4,309
    Good for you.
    But most people looking at these capacities want it for media, and again, they don't RAID (because they think it's too complicated).
  2. jwilliams4200
    jwilliams4200 Senior member
    Apr 10, 2009
    532
    I'm not sure why you quoted me but did not read what you quoted. You apparently missed the part about cloud storage.
    Also, the point I made applies to any sort of redundancy, including mirroring, WHS duplication, or even manual backups of drives. Whenever a drive fails, the replacement drive gets mostly or completely rewritten, and the faster the better.
    Yes, there are some people who buy 4TB drives and have no redundancy or backup of any kind. But it is a huge stretch to claim that most 4TB drives are used without any such redundancy.
    And as I said before, cloud storage businesses are huge consumers of large, low-power HDDs. And they definitely have some redundancy.
    #27 jwilliams4200, May 10, 2012
  3. taltamir
    taltamir Lifer
    Mar 21, 2004
    13,578
    I am not LOL_Wut_Axel, the one to whom you were being rude and condescending in this thread.
    Also, correcting people is good, its about HOW you do it.
  4. jwilliams4200
    Apr 10, 2009
    532
    Hey, a correct statement from taltamir! Not something you see every day! :biggrin:
    #29 jwilliams4200, May 10, 2012
  5. philipma1957
    philipma1957 Golden Member
    Jan 8, 2012
    1,712
  6. blastingcap
    blastingcap Diamond Member
    Sep 16, 2010
    6,656
    You may want to crunch those numbers again. EDIT: I see someone already corrected you. It bears mentioning that as platter data density rises then holding spindle speed constant you would expect higher MB/s sequential transfers, but it's still not exactly fast.
    He's on my ignore list for a reason.
    More moving parts = more potential failure points.
    RAID-style setups will become commonplace as Windows Storage Spaces becomes commonplace. About time, too, given the failure rates of HDDs. 5xxx rpm is sufficient and imho preferable due to the power savings... we're already at the point where the fastest 5xxx rpm drives are getting close to saturating GigE connection speeds on average. With another boost to density, 5xxx rpm drives will be pushing at the GigE real-life transfer speed limit. So 7200rpm gives diminishing returns unless they are local drives.
    #32 blastingcap, Nov 7, 2012
  7. Soulkeeper
    Soulkeeper Diamond Member
    Nov 23, 2001
    6,354
    25
    I just found this interesting read. Lotsa good info there.
    It seems to suggest 25% per year is the new standard/goal.
    "The use of SMR and then HAMR will not change the approximate 25 per cent a year increase in area density. That seems set to be a fixed upper rate for a good few years."
  8. glugglug
    glugglug Diamond Member
    Jun 9, 2002
    5,341
    I would be extremely leary of this. Of course maybe I am biased after being burned by the original Hitachi Deathstar when they went with 5 platters while everyone else limited to 3 in 2000.
    A normal HDD has a hole for pressure equalization with the outside (with a filter keeping particles from going through the hole. Obviously if the drive is helium filled, you can't do this, so you are going to have the pressure inside the drive increase and decrease depending on temperature. Which will cause the metal casing to bend a bit.
    Also, they conveniently forget to mention that at any given temperature, Helium atoms are moving ~ 2.7x faster than air molecules, which in addition to being smaller, makes them more likely to escape from a container if the seal isn't perfect (or escape *through* the container if there is enough space between molecules of it), which is why a helium balloon never stays full more than a day or two. Yes, I know the drive would have a better seal than a ballon, but still, do you trust the helium to stay in there for the 5 year drive life cycle?
  9. taltamir
    taltamir Lifer
    Mar 21, 2004
    13,578
    The articles do state that the advantages of helium filled drives has been known for many years and the breakthrough was in manufacturing a seal that is both effective and cheap.
  10. Fjodor2001
    Fjodor2001 Diamond Member
    Feb 6, 2010
    3,395
  11. tommo123
    tommo123 Platinum Member
    Sep 25, 2005
    2,534
    37
    the RAID analogy is fine. some home users would have a media centre RAID system to have everything on 1 drive
    also, would you trust 5TB of data on an untested drive? i always fill mine with junk data (truecrypt it) and do a full chkdsk for bad sectors. i've had a drive die on me during this so imagine if i was cut/pasting files from old to new and that happened?
  12. IndyColtsFan
    IndyColtsFan Lifer
    Sep 22, 2007
    32,593
    250
    Do you guys sit with your ears planted on the side of your computer cases? Seriously, I have to struggle to hear my hard drives and I have a server about 8 feet away with six WD 750 GB blacks in an array and my main computer is a couple of feet away with a couple of spindles.
    Back to the OP, I had heard about HAMR as well and thought that we'd see 6 TB drives within the next year or so, but who knows if that will actually happen since others seem to think Seagate can't deliver with this technology.
  13. taltamir
    taltamir Lifer
    Mar 21, 2004
    13,578
    It is there, and it is easily noticeable if you have a secondary HDD (one the OS is not installed on) and let windows turn off HDDs after idleness.
  14. IndyColtsFan
    IndyColtsFan Lifer
    Sep 22, 2007
    32,593
    250
    Well darn, I was hoping a 4 TB Red was around the corner for my new server build. I've heard they're having reliability issues with their 3 TB Reds (anyone confirm?), so maybe it is better if they take their time and get the 4 TB models right.
  15. IndyColtsFan
    IndyColtsFan Lifer
    Sep 22, 2007
    32,593
    250
    I do have secondary spindles. Heck, I even used to have a 1.5 TB Green drive and while I could hear it spin up after being idle, it was not so annoying that I'd want to eliminate 3.5" drives for 2.5" drives at this stage.
  16. Hulk
    Hulk Platinum Member
    2,556
    15
    They could deal with the pressure by having a slight vacuum in the drive so that under the worst conditions, hot drive on a plane, the casing would be equal inside/outside pressure. Most constructs can be more easily built to withstand greater pressure on the outside rather than inside. Using good construction techniques tensile stresses can be translated to compressive stresses when you have greater pressure on the outside rather than inside of a container. Of course for the relatively flat top and bottom of the drive those force (and hence deflection) would be the same. But I have a feeling that the pressure difference we are talking about here, coupled with the strength of the container would show negligible deflection.
  17. taltamir
    taltamir Lifer
    Mar 21, 2004
    13,578
    Indeed, but it is annoying enough that I disabled spindown in windows.
  18. tweakboy
    tweakboy Diamond Member
    Jan 3, 2010
    9,518
    Its coming as soon as you hit 400k in p*rn files...
  19. Mfusick
    Mfusick Senior member
    Dec 20, 2010
    500
    I think this behavior is what he was talking about.
    I honestly wonder why mods don't ban you or give you infractions more often for your behavior.
    If you check the date on the post, you'll see that it's 7 months old. This was dealt with months ago. Furthermore lashing out at another member in this fashion only makes the problem worse.
    -ViRGE
    #45 Mfusick, Dec 30, 2012
