Greetings all. I'm a new user here. I was referred by a fellow DellTalk user who said this site holds a wealth of knowledge. I came to realize that my once cutting-edge Dell Dimension 8200 is neither cutting-edge anymore, nor upgradeable whatsoever. Proprietary parts, no PC1066 RDRAM or hyperthreading support, the list goes on and on...
Anyhow, I've decided for my next computer I want to build it myself. I've read alot on the subject, and it doesn't seem to difficult. Besides, by doing so, I will be the master of my own destiny. I read about Serial-ATA, how the first generation will yield sustained rates of 150mb/s, the second generation 300 mb/s, and so on. I know there are a few motherboards and a few PCI cards with Serial-ATA connectors on them. However, I have been unable to find an drive manufacturer's roadmaps to figure out when the Serial drives will hit the streets. SIIG does make an IDE to Serial adapter to snap on the back of existing drives, but this is only capable of 133mb/s. Just wondering if any of you know anything about Serial ATA's debut. From all my research, I have concluded that the real bottleneck in any fast/well-equipped system such as mine is the hard drive. So, like I said at the beginning of this diatribe, I want to build my own using the Serial-ATA capability. I am also looking at one of the Koolance cases, with a water-cooling system installed. I am unable to overclock anything on this computer. I imagine once I build mine, I may want to dabble a bit. But noise will be a big issue and I will want the system to be as quiet and stable as possible.
Any thoughts??? Thanks in advancce
