Tinsley847
I know I am jumping the gun a bit on GPU upgrading. I'm just a huge believer in having a plan (even a loose one) for what I want to do next. My guess is that it will make the most sense for me to make the leap when the next generation is released.
Also when I bought the 6990, I knew very little about what I was doing. I had no idea that I should have been buying (2) 6970 instead. Also, I'm pretty sure since I only run 1 monitor, that it was the wrong GPU for me all together.
System Specifications:
I. Processor/CPU: I5-3570k, No Overclock.
Edit: I might make a simultaneous jump to an i7-3770k when I buy my GPU upgrade.
II. Current Graphics Card: HIS Radeon HD 6990 4 GB, No Overclock.
III. Display Resolution: 1920x1080 (I only use 1 monitor)
IV. Power Supply Unit Specification (Brand, Wattage, Ampage, Age). If possible, please provide a link to a website containing the power supply specifications: If I need a bigger PSU, I will buy one. So, this shouldnt factor in too much. Currently using a Coolermaster 850w, 80plus bronze.
V. Case Specifications(N/A, Model, Length, Low Profile, Cooling, HTPC, Water, Silent): Thermaltake Overseer RX-I | Black Full Tower
Purchase Details:
I. Budget? Please be sure to include currency (If not USD), retailer preferences & specify whether rebates are a viable option. $500-$1000 & I typically order from Newegg, Tiger Direct, or Amazon.
II. Any particular preferences (Manufacturer[nV or AMD], Brand[XFX, Sapphire, EVGA, etc], Cooling Solutions)? I dont want to aftermarket cool anything. I also prefer not to overclock.
Im getting to the point where I support AMD simply because I dont agree with PhysX implementation. Biggest issue being, the disabling of a secondary nvidia card in a primary amd rig.
However, it really sucks to spend $800 for a gpu solution (6990) and still have to turn graphical settings down or off (PhysX). I know it is just eye candy, but thats kinda what you expect to get with a top end gpu.
III. Do you plan to have any Multi-GPU solutions such asCrossfire or SLI? Im not sure. The closest I have gotten to xfire is a 6990.
IV. Have you previously looked at a product(s) which you feel would fit your needs? I was looking at the GTX 680 4gb as a possible upgrade. But Im debating if I should wait till the next gen gpus are released from amd/nvidia.
V. What are your needs for this GPU? Which games(If any)do you intend to play? If you have this information at hand, what are the desired detail levels?
Battlefield 3: Max Settings
Borderlands 2: Max Settings
Starcraft 2 Heart of the swarm: Max Settings
Crysis 3: As high as I can get w/ a stock 3570k.
Not released yet
Dead Island Riptide: Max Settings
Battlefield 4: Max Settings
I like to play whatever is new for the most part. I tend to buy a lot of AAA games and then finish a small percentage of them lol.
VI. Do you plan on overclocking the card you intend to purchase? No.
Purchase Details:
Not released yet
