When using speedfan there is one temperature that seems dangerously high..
Therk
Ok, every time I use speedfan Temp#3 seems to always be 69-71C with the burning icon. Everything else seems fine...
Can someone tell me how i can find out which component in my PC that is?
Heres what Speedfan says:
Temp1: 25C
Temp2: 25C
Temp3: 69C
Temp: 1C
Local: 33C
Remote: 38C
HD0: 40C
Core: 37C
specs:
A64 3200+ Venice (most likely to be?)
1 gig ram
Geforce 6800 GS (The temperature is not it, its at a stable 42C in nvidia menu)
200 gig HD
I don't think that the third temperature is operational. First is the MB, second is the CPU and the rest are specifically given. On mine, it shows 127 degrees, and I know that nothing is that hot, so I leave it disabled.
You're right, everybody's readout will be 127C and it nothing to be concerned about. It something that speedfan has a value for which means 0, but read as 127C. Scarey for most when they first see it. Don't worry.
on my rig, speedfan detecs a temp of -1C so its obvious that its irrelevent (i'm on air.) the temps that i have are the CPU socket, core and hdd.
feel around in your case, 70C is very hot to the touch. Do you feel anything that is uncomfortably hot to touch?
