When roughly calculating vehicle's REAL Horsepower...
Ornery
17
Some people don't want your gutless weedwacker engines, no matter how much HP it has at 8,000RPM!
vi edit
62,484
8,345
Not sure if that's directed at me or not. I don't like to have to rev an engine to get power. Never said that. I prefer cars that have a flat torque curve so that I've got power on hand at any given RPM and I'm not penalized for wanting to stretch out the gears nor am I stuck with a gutless engine at low RPM's in a given gear.
The VR6 in my old GTI was one of the most driving friendly engines I've ever had the pleasure of owning. It didn't have frame twisting torque but it was certainly enough to put a smile on your face and it was usuable at about any place in any gear.
WinkOsmosis
Banned
Sep 18, 2002
13,990
Fvck horsepower, especially as it relates to hyper screamers. That reminds me of the amplifier power wars of 20 years ago, when they used 'Peak Power', instead of RMS, to advertise their crap. Torque is what feels like true power!
No. Area under the hp curve is what feels like true power. I'd like to see how much fun you have driving a car with 1000ft/lbs from 1000 to 2000 rpm and a 2500rpm redline. No matter what way you slice it, X ft/lbs at 5000rpm is more power than X ft/lbs at 2000rpm.
Also, you have to be a moron to not understand the relationship between horsepower and torque. Horsepower at any given rpm is a product of torque and rpm.
WinkOsmosis
Banned
Sep 18, 2002
13,990
Originally posted by: cr4zymofo
I can't even believe people are associating HP with Torque, how the fcuk? Torque has to do with gearing, and given the same gearing, the more HP applied will result in more torque and higher speed. If you have completely different gearings, then it doesn't really matter how much HP you have, you could have less torque than something that has half as much HP. Don't you people know anything about basic physics?
No. They just say "torque is what you" this and that and "hp is what" blah blah. And they really have no idea what those things are.
It is likely that a small I6 is making more torque at 6000rpm than a big ol' V8 is making at that same rpm. Torque at high rpm IS MORE PRODUCTIVE than torque at low rpm, or else sports cars would have diesels.
Ornery
17
No, that's for cr4zymofo, or dumbmofo, as the case may be.
moonshinemadness
2,254
True, but you can't ignore horsepower. A Vette w/ 190HP wouldn't be much fun now would it?
Wouldn't have any torque either I bet.
Nothing like a car getting effortlessly up to speed. I just can't understand the thrill of rowing through several gears to get up to 50MPH :confused:
Try 8 gears to get to 25mph,
125hp turbo diesel
6cyl
max torque (SAE lb-ft) 38.2@1200 rpm
torqe rise 24%
7.5 litre
that may be wrong was all i could make out from a very badly scanned brochure for a ford 8340 ag tractor
Thegonagle
9,773
Ha ha ha ha ha!
Engine torque (at the crank), engine RPM, and engine horsepower ARE inseparably related! It's so simple, yet such a rough concept for some. But it is fact. If you don't have torque OR you don't have RPM, you don't have horsepower. You get nothing!
(Where's that damn formula.)
EDIT: Ah, here it is:
A simple damn linear equation with all the pesky unit conversions out of the way for you courtesy of the number 5252.
ft/lbs torque x Engine RPM = Horsepower
. . . . . . . . 5252
Rearranged, just like in 8th grade, it could also be used in reverse:
Horsepower x 5252 = ft/lbs torque
. . . Engine RPM
Go figure! ;)
Stay in school, ya'll!
sillymofo
Banned
Aug 11, 2003
5,817
Originally posted by: Thegonagle
Originally posted by: cr4zymofo I can't even believe people are associating HP with Torque, how the fcuk? Torque has to do with gearing, and given the same gearing, the more HP applied will result in more torque and higher speed. If you have completely different gearings, then it doesn't really matter how much HP you have, you could have less torque than something that has half as much HP. Don't you people know anything about basic physics?
Ha ha ha ha ha!
Engine torque (at the crank), engine RPM, and engine horsepower ARE inseparably related! It's so simple, yet such a rough concept for some. But it is fact. If you don't have torque OR you don't have RPM, you don't have horsepower. You get nothing! (Where's that damn formula.)
While we're on the subject, we're talking about torque & HP at the WHEEL, where it really counts. And I did make the distinction of different engines and transmission gearings.
Wait, how did that go again? Oh, ha ha ha ha ha ha! an HA! for good measures.
Edit: well shiet, it started out as power to weight ratio any way, in which case, my fcuking R/C car will pwn any of your cars (scale 1/4 mile ;))
NeoPTLD
2,544
125hp turbo diesel
6cyl
torqe rise 24%
7.5 litre
38.2 is obscenely low. You sure it wasn't 382 which would be more appropriate given the other paramters you posted?
Ornery
17
"...No matter what way you slice it, X ft/lbs at 5000rpm is more power than X ft/lbs at 2000rpm.
Also, you have to be a moron to not understand the relationship between horsepower and torque. Horsepower at any given rpm is a product of torque and rpm."
Your weedwacker engines have minimal torque from the get go. It's you who doesn't understand that it's NOT comfortable to listen to an engine reving so high, and so frequently to make up for this lack of power/torque. An engine with more torque means less RPMs and shifting required.
WinkOsmosis
Banned
Sep 18, 2002
13,990
If you're trying to accelerate as fast as possible, loudness doesn't matter.. What noise matters for is cruising. As for requiring less shifting... The number of times you shift depends on horsepower, not torque. Because a bigger engine has a lower rpm limit, you have to shift it sooner. It just means you have compressed shifting and powerband. A 5.0L V8 with a 2.00 axle ratio will behave similarly to a 2.5L I4 with a 4.0 axle ratio, if they have the same transmission, make the same horsepower, and so on. The only difference you would perceive is the sound.
From Roger's link, would you want a 2600 ft/lb 12rpm waterwheel driving your car? Like that site says, you have to gear an engine up or down.. Torque at the contact between the tire and the ground is what accelerates a car, not torque at the flywheel. Also, according to that site, the length of time an engine pulls is important. The longer you can stay in each gear, the better.
OS
15,581
THAT IS SO ASS BACKWARDS I DON'T KNOW WHERE TO START.
BatmanNate
12,444
Originally posted by: LOLyourFace
I simply do: Horsepower / Weight =
Is that about right? Anything else I should factor in? How about torque?
The Mazda 6 is slow. I'm sorry.
BCYL
7,803
wtf is hp / weight?
it's clear you know nothing about the topic.
it ur talking between crank and wheel hp, there's no accurate "formula".
a dyno will give u wheel hp, which in itself is also inaccurate due to different conditions and types of dynos.
the approximation from the drivetrain loss is anything from 10-25%
I'm talking about a simple applicability of horsepower. For an example: An Altima has 175 horsepower vs Hyundai XG has 210hp. But XG is much more sluggish because it's about 1000 lbs heavier.
That's what I meant.
There's no simple answer to that question... weight is definitely a factor, but not the only one...
Torque is also a factor, but also where in the powerband does the engine make it's power, how flat the torque/hp curve is, etc...
You just can't tell how fast a car is just by looking at the numbers...
Ornery
17
I had a 400ci GTO that I could drive around all day in second gear and NEVER shift. That's what an engine with torque can do. I ran that car hard a LOT, but it still spent 99.5% of the time just getting me from place to place. It had a 4sp that I'd gladly have replaced with a turbo hydromatic, and it still would have been PLENTY fast enough. A nice, comfortable Buick would make a helluva lot more sense on city streets, than a hyper go-kart. You're going to be stuck behind umpteen other cars most of the time anyway, so WTF?
Iron Woode
31,330
12,840
There is an old saying goes like "its better to let people think you are a fool, than to speak and remove all doubt".
Learn from this saying, please.
You obviously don't know squat about diddly when it comes to internal combustion engines and/or cars.
Please stop posting until you learn something.
Howard
47,982
11
Yes it would if it had 500 L.B.S. of torque.
Whatever. I'd love to have a 2000RPM redline.
Howard
47,982
11
Nah, that's just the transmission. If you had the same gearing as a car that "needs to row through the gearbox to get to 50MPH" you'd be doing the same thing.
Sorry about pointing out the 2K RPM thing, I didn't read all the way through and I'm too lazy to edit. :p
amdskip
22,530
13
That first link seems pretty accurate to me.
Old Dragster:
1575 car
8.30 seconds
165mph
Using the ET method, I come up with 544 horsepower
Using the Speed method, I come up with 552 horsepower
New Dragster (estimated):
1700 car
7.90 seconds
175mph
Using the ET method, I come up with 681 horsepower
Using the Speed method, I come up with 711 horsepower
