When it's hot : what do I do with the fan?
Kenji4861
Banned
Jan 28, 2001
2,821
It's so hot and stingy that I am, I bought a fan.
I need some basic physics help.
There is cool air outside during the night.. now
Do I...
1. Put the fan next to the window facing inside (bring the cold air in?)
2. Put the fan inside the room facing outside the window (blow the warm air out?)
3. Just make the air flow in a circle in my room ( just make the air move )
chambersc
6,247
point the FAN so that it blows toward you. it will suck in the cool air from outside and blow it at you.
DainBramaged
23,454
41
Well, I don't know about all the physics of it but I know that I point my fan toward the inside just so I get air blowing on me.
Leper Messiah
Banned
Dec 13, 2004
7,973
8
You want to bring the cold air to the thing that needs to be cooled off (you).
Gawd. Haven't you ever done case air flow setups?
Jeff7181
18,368
11
Knock out two opposing walls and fill each hole with fans... one "fan wall" facing inside, and the other "fan wall" facing outside.
Journer
Banned
Jun 30, 2005
4,355
i have an in windows a/c w/ some mods :D One dryer hose tub goes to me...the other goes to my puters
<^> you ambiant air >)
revnja
2,864
i always have my fan sucking air out of my open window. Open the door to the room to increase airflow and :thumbsup:
alien42
12,876
3,303
1 box fan blowing out a window at one end or side of the house and an open window on the other side (where you are) will cycle air through the entire space between the open windows and worker wonders like an attic fan
LongCoolMother
5,675
im gonna guess that having it blow on you would cool you off far more than having it 'suck' air away from you. evaporative cooling. splash some water on your neck and then have it blow on you. talk about the CHILLS! cooooold.
neutralizer
11,552
You want air to enter from one side of your room and go out the other. Your choice on whether you want the fan to suck or blow. But if you want to cool fast, bottle of water mixed with alcohol, spray into the air.. Cools the air instantly.
Gunslinger08
13,234
Even with the window closed, you'll feel a lot better with a ran blowing directly on your head or chest.
Jul 16, 2005
114
Hmm....Interesting.
MrX82
61
Originally posted by: pinkeywear
Maybe if you put ice cubes inside the fan it'll spread cold air.
You can fill a wastebasket with ice, point the fan into the wastebasket and cold air will come out
