- Aug 25, 2001
- 56,570
- 10,203
- 126
My main rig is a Ryzen 3600 (6C/12T), with 240mm CoolerMaster AIO LC kit for AM4, decent case, optical drive, 4x8GB Trident RGB 3600 DDR4 RAM, and currently, 2x Asus TUF GTX 1660 Super cards, mining on GPUs and CPU. Antec 750W Gold PSU. Storage is a pair of Intel 660p 1TB QLC NVMe drives.
I've been having more reboots lately, and they're happening more often since I starting doing PrimeGrid for a race. I should note here that I had my RAM @ XMP 3600 (runs mostly fine), FCLK @ 1800 (to match RAM), and CPB and PBO DISABLED, which means that my CPU maxes out at 3.60Ghz Ghz, rather than 4.0Ghz all-core, and my temps under water are mostly maxed @ 70C. Yet I get reboots.
Something really obscure, blue-screen, something about kernel access levels and IRQLs and locks, but not the usual "IRQL greater or equal" one.
I don't know if it's my RAM, my CPU, my mobo, my PSU, or GPUs or GPU drivers, or even my Windows 10 installation (fully patched, AFAIK).
I could start swapping components, run for a week or two to test, and keep testing, but what it the problem is more-or-less "systemic", "old system"?
I don't particularly WANT to replace the whole thing, but I could. I have some X370 mobos with 5GbE-T ports on them (ASRock Professional), and I could get some 3900X CPUs to drop in for $450 or so, I believe. Along with some 3600 RAM, and some fresh new SSDs (have a couple of unused 2TB ones).
Maybe I should update my AMD chipset drivers, and my NVidia GPU drivers, to start with, that would be something that would be basically zero-effort to try and fix the issue.
Edit: OK, updated my AMD chipset drivers for B450 for Windows 10, there were new ones, and updated NVidia drivers to the newest "Studio Drivers".
Edit: Oh, whoops, my current mobo is an Asus B450-F ROG STRIX Gaming ATX. Newest BIOS for Win11.
