Fair enough... What size is the defining line between phone and phablet for you? (And is that in screen size or device size?)Speak for yourself... The g3 is a phablet as far as I'm concerned
I consider a 4.7"+ 16:9 phone a phone, but awkward to use one-handed.4.7" iphone? Almost a phablet. Probably PRETTY close.
5.5" iphone? Oh hell yeah that's a phablet. I don't care if the bezels were non-existent on the sides and the LCD actually made up the side of the device. Phablet.
Anything greater than 5" is on the threshold IMO, and 5.5" is definitely a phablet. The original Note which seems to have kickstarted the whole phablet thing had only 5.3" screen, so anything bigger would fall into the same category in my eyes. IMO the test is a simple one... how easy is it to reach the top of the screen and open the notification panel with one hand? Some people have less of a problem because of longer fingers, but a 5.5" screen will often require two hands to do everything.
Yup which is why a larger size iPhone is going to be huge compared to competition. They can't get rid of the bezels. Plus iPhones are not rounded, they all have sharp corners which makes them feel larger as well. Rounded edges on larger phones makes them feel smaller and easier to hold in the hand.Keep in mind, the G3's tiny bezels make it about the same size as an m8 or GS5. Its really not that big.
It's hilarious how you attempt to spin everything, even this admission that Samsung was right and St. Jobs wrong about phone sizes, as a win for Apple.However, I suspect that Apple also is rebelling against Samsung's "every new model must be bigger, always" approach, where actual comfort and usability take a backseat to marketing.
That's Sony or HTC. The Note 4 is going to be smaller than the 5.5" iPhone... *and* have a bigger screen.If you want an iPhone phablet, fine -- but we're not going to give you a 6-inch behemoth that might not even fit in your pocket.
That's all well and good, but the large screen size still means I'm reaching to get to the top of the screen. All the bezel cutting in the world can't change how tall that screen is. I don't have big enough hands to use it comfortably.Keep in mind, the G3's tiny bezels make it about the same size as an m8 or GS5. Its really not that big.
That's probably the best definition I've ever heard. Although I still think the term "phablet" is awful.IMO the test is a simple one... how easy is it to reach the top of the screen and open the notification panel with one hand? Some people have less of a problem because of longer fingers, but a 5.5" screen will often require two hands to do everything.
We can both agree on that. I've only said it out loud once and I regretted it immediately.That's probably the best definition I've ever heard. Although I still think the term "phablet" is awful.![]()
