This same thread is being so overdone.
Okay, Heres the inside scoop from someone "in-the-know" at MS.
Windows ME is an absolute farce. If you think that win98 SE is not stable enough for you then you should be using Windows2000. The major upgrades from 98se to ME are so pitifully small that its sad. Media player is an absolute peice of crap. System restore has its moments, but dont expect miracles.
98SE is faster, drivers are more stable and if you are smart enough to put it on its own partition, defrag periodically, own a virus-checking software program, make YOUR OWN back up of your registery (whew) and with all of that simply be careful of uninstalling and installing a bunch of crap all over the place...you should be satisfied with the performance.
Also, If you put a machine with 98SE and ME up against each other and instead of spending the money on ME, put more memory in the system, you should see a major performace increase.
Simply put, more memory = faster performance.
I would seriously doubt that anyone has much better performance under any circumstance with ME over 98SE
ESPECIALLY in the TCP/IP stack. Because they are virtually identical in every aspect.
IMO Whistler is going to make this entire argument obsolete.
So, the moral to this story is:
Put more memory in your system, Wait until Whistler comes out, Run 98SE (better yet Dual boot 98SE/Win2k, play games and what not.
Good luck
