I have tested about 36 old monitors lately to see if they were working. I have found that frequently when they do not work they usally do not turn on when you push in the On and OFF switch. The LED does not even come on. It is as if there is no power coming to the switch. What part in the monitior is usally at fault when this happens? Is it possibly a fuse? Also the second most frequent occurrence when they do not work is that diagonal lines show up across the screen. What part in the monitor is most frequently at fault when this happens. Thanks for your help.
