wheel/tire issue
Status
Not open for further replies.
slag
My car came with aftermarket rims that don't fit my hub correctly. It also has a spacer between the hub and rim. I need to find a ring/spacer that fill fill the distance between the center of the hub and the rim.
Is this a hubcentric ring?
Assuming this is the same car as what you were asking about in the other thread, yes, it is supposed to be hub centric.
VW uses a 57.1mm hub and there are hundreds of rings available to make anything fit. If you find out what the size of the wheel is itll be easy to find a ring.
Your spacer is (or at least should be) matched to either the hub bore on the wheel or the car.
Assuming it is, a hubcentric ring will work just fine since it'll sit flush with the inside/outside of the spacer depending on if it is matched to the car or the wheel.
http://www.ecstuning.com/Volkswagen-Jetta_V--2.0T/Wheels/Hub_Centric_Rings/ES2200633/
Thats exactly what I ordered earlier and it already shipped. Also might be interested in the 10mm spacer with lip combo..
Status
