Since I delidded my 3770k, I have a few overcloks saved with some pretty descent voltages. ran Prime 95 with amall, large, blend 24 hours each . LInx for 12 hours straight, IBT FOR another 12 hours, memtest overnight. I have also been using my 4.7 ghz for FSX and used the game for 24 hours straight meaning plane on auto with ultra settings. ran cine bench, ran vantage 06. absolutely no errors not BSOD's .
I have been reading about the whea Errors and decided to check it out . well anything above 4.6 ghz will show errors. how many for each overclock I do not know. When I ran all of those test at 4.7 and 4.8 I ran them with low voltages for example my 4.7 was at 1.315 offset. I decided to do a quick 12 hour test prime small fft at 1.344 It showed no errors on event manager. Now I forgot to mention that there are no errors on all the stressers except Prime 95 with the lower voltages. My question is does this mean I am not stable unless I raise the voltages? even though it only occurs on Prime. Or is it a software bug with Prime because I get highter temps with IBT than Prime and I was confused how I did not get any errors with IBT with the same 1.315 volts V core offset. Does ignoring the Whea errors cause system malfunction eventually? I never got any of these errors when I ran my 2700 k rig. Am I fooling myself with lower voltages? ......I know it is a lot of questions but I really need some sound advice on whea😕
