WHAT'STHE FASTEST SPEED I CAN RUN ON ABITKT7-RAID
PRATTRAT
4
I have an ABITKT7-RAID and I flash the BIOS with the latest revision, version 3R so I can take advantage of using the fastest CPU, which this version upgrade will permit. I?m using Corsair SDRAM pc133c2. ABIT states the following: ?Add new option "1200 above" for high speed Athlons with 100FSB. KT7 / KT7-RAID / KT7A / KT7A-RAID / KT7E only support 1.4G(100) Athlon with L1 bridges disconnected. Check L1 before you buy a CPU please!? my question is has anyone done this and what is the fastest Athlon they?ve used.:confused:Text
DAPUNISHER
32,126
32,701
We were just talking about this the other day check this threadKT7 info It should give you a good idea how far this board will go.
