Whats your favorite All Purpose POWER TOOL! Ohgrr Ohrr!
Cashmoney995
695
Whats your favorite All purpose power tool? Like, Those miracle ones that can cut through anything, like the RotoZip, or the Sharky extreme?
notfred
38,241
4
There are very few "all-purpose" products that are very good.
A dremel is not all-purpose. It's a cutting tool, for small objects. It's a really lousy tablesaw, and an even worse drill press.
Edit: Ok, it might work as a drill press for drilling a 1/4" hole in wood, but you'd have some difficulty putting a 1" hole through a half inch of steel with it.
Armitage
Banned
Feb 23, 2001
8,086
The right tool for the job. "All Purpose" tools ussually do nothing particularly well.
The best I can think of would be a drill. Drills holes, can be fitted with a sanding or grinding disk and do OK, drives screws, put a mixer on it and stir paint, mortar, etc, saw a water pump the other day that you chuck into a drill. You could probably chuck one of those rotozip bits into it and do a passable job on drywall.
Nitemare
35,461
4
Originally posted by: MrsSkoorb
My powered screw driver. :)
I'm so tempted to make a remark about MrSkoorb & BabySkoorb.... :eek:
I vote for the high speed cordless drill
slag
10,473
Definitely a 4 inch electric grinding wheel. It grinds, sharpens, cuts off, cuts through anything, is basically the do all tool
notfred
38,241
4
Originally posted by: Armitage
If the only tool you have is a hammer, everything looks like a nail :D
Go back to the software forum, I'm trying to fix your <pre> problems :p
Mr N8
8,793
Originally posted by: Squisher
Porter-Cable
That's a brand, not a tool.
My most useful tools are either my Milwaukee Sawzall or my Dewalt Circular Saw.
I don't like all-purpose tools. I would rather own the right tool for the job than a tool that kind of does every job.
Armitage
Banned
Feb 23, 2001
8,086
Yea, talk about the wrong tool for the job ... sometimes I feel using html is like trying to kill a grizzly bear with a frying pan :D
Dec 28, 2001
11,391
LOL!
Doggiedog
12,780
I always knew Skoorb was a tool! ;)
My vote goes to my 18V Dewalt cordless drill.
I can't believe I lived without one.
