Whats your avg. for Seti@home blocks per day?
Ken g6
Moderator
Dec 11, 1999
16,712
4,672
75
Three if I'm lucky - at least until I get my miniteam stats. :)
Shuxclams
9,286
15
weird, I have Client 3.0 running 24/7 on Mandrake 7, K6-2 400, 128MB in CLI or GUI and only manage 1.7 units a day. (?) What nice -xx setting do you all use?
SHUX
Yo Ma Ma
11,635
Here SETI is running on 3 machines, (K6-2 450, 64MB running GUI 3.0)x2 and one K6-3 450 128MB running the previous GUI release (2.04?).
Shuxclams
9,286
15
So my machine is right in there then if your 3 do 3 a daythats 1 each. :) cool I feel a little better but since this machine only has one other duty that requires very little CPU time I figure I can tweak the nice settings to get better results, any suggestions?
SHUX
Assimilator1
24,165
524
Shuxclams
I do about 9Wu's/day ,my main ships a Cel 366 @550 ,Cel 300 @ 464 ,PII 333@ 374 & a PIII 550,all these PC's run SETI 24/7.I occasionally get a PII 350@392 as well.
BTW are you on our team?
Shuxclams
9,286
15
<< BTW are you on our team? >>
Currently ranked #394.......but rising. :)
So 1 machine does about 1 a day........I have 2 others that can do it P/T so maybe I can up it to close to 3 a day. well matbe not, seems the K6-400 on Linux kicks the pants off a K6-2 450/Win98 and a Celery 366@550/W2K.....oh well, that figures. :) Should have a P-!!! 600e@800/Win98SE P/T in few weeks that should help. ;)
SHUX
Sukhoi
15,350
Lately I've been getting .3 WU/day under what [B}Ken_g6[/b] has been getting. :)
Assimilator1
24,165
524
Shuxclams
I may have got my maths wrong!:eek: ,because my Cel 550 does about 3.5WU/day ,PII 374 about 2WU/day ,etc :)
Shuxclams
9,286
15
<< because my Cel 550 does about 3.5WU/day >>
Hmmm, mine is @ 60% after 15 hours......GUI screensaver though. My Linux K6-2 400 is close to lapping it! LOL.
SHUX
Assimilator1
24,165
524
Have you enabled 'blank screen' in the screen saver settings &amp; set it to less than 5 mins? or have it 'always run' with the window minimised?
My longest WU with GUI v3.0 was 10hrs 53m
Shuxclams
9,286
15
Its in taskbar and then screensaver is set for 5 minutes. :) So however that is, its running all the time. its 65% done in 17hrs 45mins........:Q
I just looked and it is running in the background and then screensaver takes over after 5 minutes.
SHUX
Shuxclams
9,286
15
I think it has to do with the fact that I am constantly using this machine for surfing, playing yadda yadda............
SHUX
Robor
I think I'm doing a litter over 60WU/day. A 15-20 at home and 42-47 at work.
Shuxclams: Make sure you have the &quot;blank screen&quot; box checked on your Seti@Home screensaver properties. If you let the GUI client display the pretty graph you'll double the CPU time. :)
Rob
Assimilator1
24,165
524
Yeah as Rob says ,I don't mean just having the screensaver start I mean having the screensaver blank the screen after a few mins ,this kills the graphics output &amp; halves the WU time ,its not the power saving features either
BadThad
12,100
49
I have a K6-2 450/256MB RAM running v3.0 gui and it takes about 17.5 hrs/WU...so your machine seems about right. To show just how weak the K6 core is, I just put 3.0 gui on my P233MMX/64MB RAM. It did a WU in 20.5 hours! hehehehehe, FPU FPU FPU.
Oh, BTW, looks like i'm at about 30 WU's/day lately. I did some major assimilations over this last weekend, and it showed. I was up to about 40+ WU's/day. :)
Shuxclams
9,286
15
Well I have it running &quot;all the time&quot; for the time being, I am running it on W2K pro and this version doesnt have the blank screen option... its OK I have a bunch more Wu's at this point and the Linux Box is going at a decent clip....thanks :)
SHUX
Sukhoi
15,350
I believe all the GUI clients have a blank screen mode. Go to your desktop properties, click on the screensaver tab, make sure SETI is set as your screensaver, and go into the screensaver properties. On that screen should be a check box to have it go to blank screen mode. It should help your work unit times a lot, and that's better for the team! :)
Robor
Yes, like Sukhoi said, you should be able to enable &quot;blanks screen&quot; mode in the Seti@Home screensaver properties. Also, I'm not positive but I think you should have the regular &quot;blank screen&quot; as an option under Win2K. Just check your Control Panel | Add Remove Programs | Windows Setup and I'm pretty sure there's a setting under there to add more screen savers. I could be wrong but I think my Win2K had &quot;blank screen&quot; as an option and I know I enable them all when I install it.
Rob
