Let me clarify. When I have the ceiling fan running with the AC set to 79, that wind chill effect causes some discomfort. So much so that I have to grab a comforter.WTF? 79 is "kinda cold" in what world exactly? I'd keep mine at 65 if I weren't so cheap and do keep it at 65 in the winter. If it gets over 75, I can't sleep.
Jeez I live in Chicago in a 1,000 square foot apartment and my electric bill was $55 last month. During the fall my bill is around $30.My total electric bill last month was $413. Summer.. in Kansas, with kids home from school playing on computers, watching TV, etc. We also have a hot tub that runs with a circulation pump.
On my ecobee I have 3 temp sensors in several rooms and in the evening I only have the living room controlling the setpoint and at bedtime I average two bedroom sensors to control setpoint.
So in short, the evenings the living room is at temp and the rooms are below temp then at bedtime the rooms are at temp and the living room is way hotter. I'd recommend the ecobee 3 to anyone who wants to take control over their HVAC.
I wish... I don't actually know how many square feet my apartment is but it's a "decent-sized" (for NYC) 2 bedroom, and my last bill $80 with only the most minimal of AC usage (I have ceiling fans everywhere, and like fresh air...)Jeez I live in Chicago in a 1,000 square foot apartment and my electric bill was $55 last month. During the fall my bill is around $30.
78 or so isn't so bad if you're in underwear only watching tv/playing games. Minute you start doing any kind of housework or put on clothes, it becomes too hot. Probably couldn't sleep like that either. Bed is in the basement where it's ~ 70 when the top level is 78.
I'll be installing an ecobee 3 and integrating it into my HA systems soon in all likelihood. However, the issue is that I have a large two story house and the AC is probably undersized to begin with. My office, for example, suffers from low air flow so I had to get the portable AC to supplement the central air in that room - ecobee's remote sensors won't be able to help compensate for that due to the low air flow. My entire upstairs can be 5-10 degrees warmer than the downstairs, so if I move too far above 72 on the thermostat, my master bedroom is unbearable.
have you ever considered those automated vents that open and close when a room hits their setpoint?
It's crossed my mind to actually design something like this, there would be dampers for each room that are controlled by a servo, and then a bypass damper at the furnace to let some air of the supply go back in the return, if a lot of supply dampers are closed. The air that is coming out of the ones where the dampers are open would then be hotter/colder depending on if furnace or AC is running. Could have different setpoints for each room, even. Basically it would get desired rooms to the right temp faster, and probably run the system less if you set other rooms less. If using servos you could even limit supply to other rooms without stopping it completely.
Not sure what weight has anything to do with it. I'm pretty small by most peoples' standards and anything about 75 I start to sweat and not be very comfortable, especially if doing any kind of physical work. 70 and lower is the best. Though I find the temp difference alone can make a big difference in comfort, if it's like 80 outside and house is 75 it still feels good when you walk in, but then you sit down and stwell if you're an overweight slob who doesn't exercise daily then yeah, you'll need more cowbell (lower the temp).![]()
I don't know what the medical/biological explanation is (I don't think it's as simplistic as having extra "insulation"), but overweight people do typically feel the heat more than others. But I'm not overweight, and I also hate it when the temperature goes above the mid-70s (what can I say, I sweat like a horse at the drop of a hat, always have, and I don't like it!Not sure what weight has anything to do with it. I'm pretty small by most peoples' standards and anything about 75 I start to sweat and not be very comfortable, especially if doing any kind of physical work.
