What's wrong with my computer? *Problem Solved*
micron
Lately when I leave my PC on for extended periods of time it either locks-up or I get constant BSODs. What's wrong?
Sled Dog
241
Is it overclocked? If so it may be running on the edge of it's maxiumum alllowable speed. It could also be overheating, overclocking creates much more heat and the processor can run much hotter if your cpu cooling system isn't addequate. If it's not overclocked, and is an older unit, could be the cpu fan needs oil or repalcing, or heat sink fins have collected enuff dust over time to decrease it's efficiency. I f none of the above sound right, we may need more info for diagnosis. You could try reseating the memory? Power supply getting weak? Could be one of many things. Suppose it could be software, but usually one of the above.
edit- I now see by your system stats you are overclocked by 200mhz. Try increased cooling or slow it down one notch, I think this will cure your problem.
micron
Yes, my system is overclocked. Here are it's specs:
AMD Athlon Thunderbird 800MHz @ 1000MHz 1.85v FOP32-1 Arctic Silver
MSI K7T PRO2-A
128 MB PC100
3dfx Voodoo3 3000
Western Digital 20.0 GB @ 7200 RPMS
50X CDROM
Philips PCRW804K CDRW
Creative Labs Sound Blaster PCI128
Windows ME
JonB
2,126
13
www.granburychristmaslights.com
Have you upgraded to the newest client?
dnetc v2.8012-466-GTR-01020321 for Win32
I did yesterday. Got my first DNETC client crash since I can't remember when (running OGR).
I also have an OC'd MSI Pro-2A, 1ghz @ 1.263ghz 1.8V
micron
Yes, I upgraded my client yesterday, that's also when my trouble began. I think I will switch to a older version and see what happens.
SpaceWalker
791
Personally I think it could be your memory....
I see you said Micron PC-100...very good memory, I use them myself, I got 4 of them in my system right now.....but, You are running them at 125Mhz...may be a little much for you stick...try getting a stick of pc-133 and see if the problem goes away....Good luck...
MOOOOOOOOOOOOOOOOOOOOOoooooooooooooooooooo.............
[Edit] Oh OK ...I stand corrected.... :) [/Edit]
micron
Thanks JonB! switching to an older client solved my problem :D. SpaceWalker, my memory is not at 125MHz it's at 100MHz, I'm using the multiplier to overclock ;).
ViRGE
Elite Member, Moderator Emeritus
167
Humm, that's grave indeed.:eek: JonB, drop by Dnet's Bugzilla forum, and leave a bug notice.
