what's the usual going rate for a brake job ?
isekii
28,578
What's the usual going rate for a brake job ?
When I will be providing the brake pad for an Import Sedan ?
isekii
28,578
Originally posted by: fitzov
It's really easy to do this yourself.
probably is, but i dont' want to start something then not be able to complete it :p
if I provide my own pads is 40-50 bucks a standard rate ?
Squisher
21,204
66
no, much more. I would say probably more like $200, but brake shops always find more stuff wrong.
MixMasterTang
3,167
176
When you say import sedan, do you mean european or japanese because theres a huge difference in price.
isekii
28,578
Originally posted by: ScottFern
What about your rotors? Are you cutting them or getting new ones?
why would i need to swap my rotors.
my car is only 4 year old with like 26k on it.
AFAIK my rotors are fine. If all else, the shop will probably machine and clean them up a bit.
kevman
3,548
$30-40 per wheel for pad replacement labor, parts are probably 70/axle. Rotors another 80-100 for parts per axle.
Squisher
21,204
66
Some rotors are made from the factory at their low limit, so they never can be machined. They do this to lighten the rolling resistance and thus give better gas mileage.
isekii
28,578
well i haven't heard about anyone with the same car as mine getting the rotors replaced with a brake job. So i'm not really worried about it.
Fritzo
41,920
2,162
Ever since my father in law showed me how to change brakes, I've done them myself since they're so easy!
You just have to buy a big a$$ clamp, open the cover on your brake fluid resivoir, then do the following:
1) Jack up car
2) Take off tire
3) Take a block of wood, place it on the brake cylinder, then tighten the clamp until it compresses.
4) Remove the two bolts from your brake shoe, pop it off ( you can pop your rotors off too at this time if you need to). Put your new stuff on.
5) Rebolt everything, put your tire back on, move to the next wheel.
6) When done, make sure you're filled up with brake fluid, and you're gold!
I did my brakes in about 40 minutes for about $150. I used the high quality carbon fiber brake shoes to avoid squeeking. Same brake job costs $380 at Midas.
mwmorph
8,877
We charge $190 for an axle regular price, includes pads and resurfacing rotors. I think we have a sale now at $150 per axle. It's reeally all that expensive thanks to the time involved. Standard rate at dealershisp for labor is $85-$105 per hour and brakes are on average a little more than 2 hours for both axles, including resurfacing.
If you dont need the rotors resurfaced, then doing it yourself is decently easy.
CFster
1,903
1) Jack up car
2) Take off tire
OMG.
MiniDoom
5,305
It really depends on what kind of car it is. Taken everything apart is easy, just like a computer or laptop. The hard part is putting everything back the way it came without ending up with ?spare items?. I use to have an old Volvo, the brake on it where cake. A monkey could do it. The Honda I have now is a little more challenging. I got my mechanic friend to change them since brakes are kind of important and I want them done right. Luckily I was able to trade him some computer maintenance work for the brake job. He changed the front pads in my parking lot in less than 15 minutes. He told me garages usually charge two hours labor+part for a 15 minute job. So go figure.
jagec
24,442
Brake jobs are an outrageous ripoff considering how easy they are to do yourself.
CFster
1,903
Unless you have a vehicle such as a late model GM truck which requires the use of a $2500 Tech II scan tool to energize the ABS solenoids to facilitate brake bleeding.
There are other examples.
jagec
24,442
What, you CAN'T bleed them manually, or it just makes it easier to use the ABS system?
Besides, a lot of places don't do anything but change your pads when they do a "brake job", assuming the rotors and fluid look fine.
CFster
1,903
Impossible to bleed the brakes.
Goosemaster
48,775
woah..really?
