- Jan 15, 2013
- 12,181
- 35
- 91
Is an i5 just an i7 without Hyperthreading?
A standard i7, yes. The i7-E parts are different as they are based on Xeon chips.
So they're identical in single-threaded performance?
How is the i7-E different? Does it support ECC and multi-processor configurations?
I'm not certain about ECC, but multi-processor configurations are not possible with the i7-E. Intel has disabled the QPI links required to communicate between sockets.
The i7-E is the current generation workstation processor, with a few cores disabled. This is why you can get it with up to 6 cores- Ivy Bridge E Xeons can go from 6 to 12 cores. However the core is an older design than the consumer, not E series i7. For instance while the 4770k has 4 Haswell cores, the 4930K has 6 Ivy Bridge cores; the 3770K had 4 Ivy Bridge cores while the 3930k had 6 Sandy Bridge cores; and so on.
Sorry to derail a bit, but what were the 9xx series then? And was there a 29xx series? I've never seen one. What happened there?
Figuring out Intel's mobile line is a joke.
Core i3s are Dual Cores, Core i5 are Quad Cores. There is a huge difference there.So the i3 has HT, no Turbo. The i5 has Turbo, no HT. i7 has both.
Except this mobile i5 and i7 look nearly the same.
With Sandy Bridge, Intel basically split socket 1366 into two lines: 2011 and 1155. As an example, the 920 had triple channel memory, while SB had dual channel and SB-E had quad. I'd argue that SB-E should have been called 29xx because it's a second-generation i7, but it's all in the marketing.
Honestly I don't mind looking up the specs of any given CPU to familiarize myself with the intended product, it's just that so many vendors can't seem to be bothered to accurately list what the thing has in it, and act like you are from outer space for insisting upon having accurate info...
What was it based off of though? From what I can tell the i7 9xx was separate from anything else, then they skipped the 29xx, then named all future x9xx series one ahead of the true architecture.
Wikipedia has sorted out quite well the naming issue. They have a few, organized tables based on specs instead of mere naming:
List of Sandy Bridges
List of Ivy Bridges
List of Haswells
