What's the proper method for crimping wires (connecting new car head unit)?
Techie333
2,368
I am installing a new car head unit and I just want to know what the proper method is for crimping or connecting the wires together. I will be using insulated closed ended connecters. But, do you spread each of the thin copper wires out and then put them together and twist. Or do you twist each individual one first and then try to connect them?? Thanks.
Heisenberg
10,621
You're using the screw-on cap connectors? Just put the wires side-by-side, and screw the cap on.
Dufman
1,949
that is the best way to do it
Techie333
2,368
They aren't srew-on caps, i got them from radio shack, they are crimp-on nylon-insulated closed end connectors. It says they can be used for telephone and alary system connections.
Templeton
just remove 1/2" insulation from each wire, twist together, and throw the crimp on. You might want to consider soldering and heatshrinking if you have the time, it's alot more permanent and you don't need to worry about the crimp ever falling off.
Heisenberg
10,621
Can you either post a link or describe the connectors a little better? I'm still not clear on what you're using.
Edit: And yeah, soldering+heatshrinking is the best way to go if you can.
OrganizedChaos
4,524
are you using spade,butt, those snap together connectors, or maybe something diffrent? if the connectors are red/blue/yellow you just stick the wire into the connector and crimp with the corosponding colored notch on your crimp tool.
Thegonagle
9,773
That's what I do. But twist and crimp is loads better than twist and tape. Make sure you're using the correct size crimp thingy, or it's likely to fall off at some point. (Connecters for "telephone and alarm" wires don't sound like the right size to me.)
LordJezo
Banned
May 16, 2001
8,140
Spend the $5 and go to Home Depot and buy a pack of the screw on wire connectors. Super simple to use and they work. What more could you need?
You dont need any soldering or anything else fancy for hooking up a head unit to a car. The screw on kind do exactly what you need and are cheap and easy to use.
Techie333
2,368
So with the screw on, you just put the wires next to each other, and then just screw the cap on?
Techie333
2,368
Right now, I did hook it up by hand and then putting the radio shack connectors. However, the volume is way to sensitive. At a volume level of 02, it is already really loud. I probably can't even go past 07 w/o blowing the speakers! I am thinking about getting the home depot screw on caps because I think it might be bad contact or something? Perhaps it is the amp-on wire?
Spencer278
3,637
The connection shouldn't increase the volume. Check to make sure all the speakers are working.
Techie333
2,368
huh? What does speakers working have anything to do w/ volume control problem. Yes, they all are working...
