S Sukhoi Elite Member Dec 5, 1999 15,350 106 106 Jan 4, 2006 #1 I need the capacity with filter. I'm thinking it's 3.2 quarts, but I left my manual at school.
S Sukhoi Elite Member Dec 5, 1999 15,350 106 106 Jan 4, 2006 #3 Well I'll just call the dealer tomorrow if nobody here knows, but I wanted to check and make sure I have enough oil in the basement.
jlee Lifer Sep 12, 2001 48,518 223 106 Jan 4, 2006 #4 If you have 3 quarts, buy another. If you have 4, you're probably all set. I had a '98 (1.8l 1ZZFE)..I think it took 3.9 quarts - not positive, though.
NutBucket Lifer Aug 30, 2000 27,169 643 126 Jan 4, 2006 #5 4 is standard for most cars with 4 bangers.
N NVulture Junior Member Dec 29, 2002 8 0 0 Jan 4, 2006 #6 3.0 qts including filter for the 1.6L engine. 3.7 for the 1.8L engine. Chilton's manual...
S Sukhoi Elite Member Dec 5, 1999 15,350 106 106 Jan 4, 2006 #7 Originally posted by: NVulture 3.0 qts including filter for the 1.6L engine. 3.7 for the 1.8L engine. Chilton's manual... Click to expand... Thank you!
