What's the noise level difference from 45dba to 47dba?
brxndxn
8,475
45dba is an annoying 6000rpm fan.. 47dba is an even more annoying 6800rpm fan
ElFenix
102,406
8,585
eh, the really annoying thing is the frequency of the noise
Viperoni
11,084
10db is typically considered "twice as loud" by humans.
In the land of speakers, to achieve an increase of 3db, you have to either: double the power, or double the cone area while maintaing the same power level.
For fans, I asume 2x 45db fans would net you 48db, however, as ElFenix said, it's usually the frequency of the noise rather than the noise itself that is most annoying.
lowtech1
4,644
Originally posted by: erikiksaz
I forgot how the whole thing works, but would that be a big jump in noise?
If I remember correctly: 45db +3 = twice the noise level/energy of 45db
erikiksaz
5,486
It's still suprising that these Western Digital SE drives are so loud! It's 47 dba. I wanted to get the Seagate 15k.3 in the future, and it's 2 dba's quieter. Aye, i have to find a way to silence it all!
