ofiraltarasy
- Aug 5, 2005
- 910
- 0
- 71
if your mobo came with integraded graphics that will work fine if you dont have one anything will work i suggest a 64MB one
Originally posted by: dexvx
Originally posted by: batmanuel
Not only has the 2D quality on the current nVidia and ATi value products caught up with the once-venerated G550, but the newer cards have the larger 128MB memory and DX9 shader support that you could need down the road if you plan to upgrade to Windows Vista. The G550 was a great card in its day, but that day has long since passed (you'll notice that most of the reviews that rave about its 2D image quality are from 2001 and are using the GeForce 2 MX, the low point of the GeForce series 2D image quality, as a point of reference). I really can't recommend anyone buying a new graphics card below the X300 (non-SE)/GeForce 6200 level with less than a year to go until Vista's launch. You'll be saving money in the short term, only to wind up spending more down the road if you want all the Aero Glass eye candy a year from now.
That makes no sense.
Why would he spend $100 or so on a X700 or similar because of Windows Vista, which is going to launch months from now? When Vista actually does come out, $100 will buy you a much better card.
