whats the max length for a printer cable?
Discussion in 'Peripherals' started by mcveigh, Jul 22, 2003.
  1. mcveigh
    mcveigh Diamond Member
    Dec 20, 2000
    6,457
    google was no help :(
  2. Loading...
    Similar Threads - whats length printer Forum Date
    Movidius, what does it actually do? Peripherals Jul 20, 2017
    What is the best Keyboard and mouse that can be used with PS/2 Ports? Peripherals Jul 17, 2017
    What is a gaming keyboard? Peripherals Apr 15, 2017
    What is the maximum allowed length for a usb cable? Peripherals Nov 4, 2001
    What cable length for speakers ? Peripherals Aug 6, 2001
  3. fredtam
    fredtam Banned
    Jun 6, 2003
    5,694
    I think for 1284 it is 25'.
  4. Drakkon
    Drakkon Diamond Member
    Aug 14, 2001
    8,403
    nahhh...we ran a special order 50' cable in office building one time...had no problems...
    but really better to setup a print server and just use the network...
  5. Wizwill
    Wizwill Junior Member
    Jul 24, 2003
    Conventional wisdom says 15' for a parallel cable and the same for USB. If you use a quality brand cable 25' parallel or USB should be OK, and I have seen 50' pre-made parallel cables. The real problem is signal voltage drop over long runs.:)
