Originally posted by: isasir
It seems that some people recommend a 400W power supply for the 2400+ CPU I was looking at...
Yes, if your psu isn't putting out enough on the 12v rail, it can ruin the drive motors in your hard-drives. Of course, that's quite rare, since the cheap psu's usually have plenty of 12v juice; they just usually lack in 5v amperage, which will only lead to stability problems.Originally posted by: isasir
Well I was looking at a 2400+, so it seems like I should be ok then.
Can a power supply that isn't strong enough do any permanent damage to any of the computer components? I'm assuming not, but I want to make sure.
Thanks.
