What's the difference in Firewire 4pin and 6 pin?
Theguynextdoor
1,118
Just wondering? Also is there any difference between USB2.0 and Firewire? I use Firewire 4pin to 6pin cable to transport my AV from my digicam to my PC. But it has a USB outlet too but doesn't work. My coworkers also tell me there's a new firewire coming out. Just wondering if any of this is true.
xylem
621
Firewire has a theoretical max throughput of 400 Mbps, USB 2.0 max theoretical of 480 Mbps. However, firewire has a higher sustained transfer rate, based on the comparisons I've seen, and is the superior interface. The newer firewire that your coworkers speak of is probably Firewire 800, which has a max throughput of 800 Mbps, and is already in production, though not widely so.
edit: Also, 4 pin firewire is data only, 6 pin has data plus power.
corkyg
Elite Member | Peripherals
27,370
239
Boston Dangler is right - 4 pin F/W carries no voltage - just data. 6 pin carries power for the device. Camera ports always are 4 pin because they have their own power.
imported_rod
1,788
Yeah, what everyone has said sounds right.
6-Pin firewire connects have 4 pins for data, and two to suply power. 4-Pin connectors carry no power, only data.
Also, Firewire is faster than USB and USB2.0, and firewire 800(1394b) is faster than firewire 400(1394a).
Firewire 800 > Firewire 400 > USB 2.0 > USB 1.1
RoD
MobiusPizza
2,001
RoD
And FireWire LAN rocks :?
