I'm ordering an Retail ATI 8500 and the LE version is $90 cheaper than the regular 8500. IS the the 8500LE clocked lower then the regular 8500 or is it at 275/275?
$90 difference? Go grab the retail 65MB 8500 from Newegg for $164 shipped, the 64MB LELE (230Mhz) is $134 shipped so for the extra $30 go with the retail box version....
The R8500LE is clocked at 250/250 by default whereas the regular Retail boxed 8500 is clocked at 275/275.
The 'LELE' is clocked at 230/230.
The 8500DV is clocked at 230/190.
The R8500 Low Profile is clocked at 230/200.
The performance difference between the full R8500 and the 8500LE is generally about 7-8%. Though that can vary depending upon the amount of DRAM on the card, and whether it uses DDR SGRAM or SDRAM.
