What's the difference between an expensive circular saw and an inexpensive one?
mugs
48,920
46
I was at Lowe's looking at saws, and they range from $40-$200 (the $40 one being a Skil, which I wouldn't consider a no-name brand). What difference would there be between an inexpensive one and an expensive one (other than price, so don't waste your time posting that)? I wouldn't use one on a daily basis, so I'll probably go with one in the $60 range - is that a bad idea?
Demon-Xanth
20,551
The biggest difference is in the bearings. One will a decade if you use it one day a month. The other will last 5 years if you use it 60 hours a week.
NutBucket
27,127
616
Yeah. I think that's why my dad finally had to buy a new one. His Black & Decker was so old it was in a green housing! Prolly had it a good 20 years of light-moderate use.
TechnoKid
5,575
Basically, it what Demon says, bearings, and the insulation of the motor and the amps the motor has.
mugs
48,920
46
Originally posted by: NutBucket
What are you going to be doing with it?
Cutting wood, mostly. ;) Various projects around the house. First project is a bookshelf.
NutBucket
27,127
616
Then I wouldn't get one more then about $70 or so. It should serve you well for many years:)
