What's the difference between a suit and tux?
dudeman007
3,243
Questions is obvious. I need to know for prom. Honestly I don't see much of a difference. Should I just stick with my suit and screw renting a tux?
ElMonoDelMar
1,163
338
Bah, I graduated from HS last year and my GF is a Sr this year. I'm not gonna fork over the dough for a tux. I'm just wearing my suit with some colored shirt, MAYBE even a new tie if I'm feeling ritzy.
510echo
10
they are very similar, although tuxs have a satin lapel and a satin stripe down the leg.
tweakmm
18,436
4
A tux has a special jacket, special pants, special shirt, a cummerbund and a bow-tie. Basically, completely different.
huesmann
8,618
A suit can be any color. A tux is always black, although you can get a white dinner jacket. Also, with a suit you wear a regular tie (unless you're dorky and wear a bow tie). With a tux you wear a black bow tie.
The girl you go to prom with will want you to wear a tuxedo.
Sex Smurf
1,384
If anything, buy a new suit for the prom. You can use it later in life for your job interviews.
Rented tux's usually use cheap materials and definitely look cheap, whereas a new suit will make you stand out from the crowd.
randomlinh
linh.wordpress.com
new suit's usefulness for job interviews.... that all depends on how much beer and pizza you consume in college :)
gshock888
Banned
Mar 28, 2003
1,762
either way ur not going to get any dressed in those. what's important is that you will hopefully get out of those clothes
beatle
5,661
Tux doesn't have to have a bowtie + cummerbund. My last tux had a vest.
Sex Smurf
1,384
That is true. I put on 10lbs between HS grad and college grad. . .
purbeast0
53,559
6,391
dude just rent a tux. you don't want to wear a suit to prom. if you do, you will probably be the only one wearing one at prom. there are great varieties you can get with a tux, including the color of the shirt, the vest, etc.
just go rent a damn tux, you can only go to your senior prom once.
BornStar
4,052
Trust me, you'll wear a tux. Your g/f will make sure of that.
Sex Smurf
1,384
Originally posted by: gshock888
who else thinks that he looks better in a suit than a stupid tux?
i do i do. tux = sucks
Unless you buy a tux which was made with high quality wool, tux = sux
thomsbrain
18,148
wear the tux. in HS everyone is so anal about conformity and doing things the "right way" that your GF will be ashamed to be with you if you don't wear one (even if she won't admit it). rent the stupid $60 tux and don't worry about it.
