What's the difference between a primary partition and an extended?
Banned
Feb 17, 2003
1,948
Why bother with primaries when you're limited to 4?
Why not 1 extended and a bunch of logicals?
DannyBoy
8,820
www.danj.me
Hang on, excuse me for being ignorant but which question are you asking?
or
the 2nd one makes no sense?!
hjo3
7,354
4
Well, you need at least 1 primary for the OS, right? Shouldn't matter how you partition the rest of it; you're still going to basically have the same amount of disk space.
DannyBoy
8,820
www.danj.me
Sounds about right
dunkster
1,473
Single-OS system configuration requires one primary partition for the OS.
Multiple-OS system would require one primary partition for each OS installed on the HD.
If an extended partition is created, it is also considered to be a primary partition (according to PartitionMagic).
Hope this helps!
Whitedog
3,656
Extended/Logical partitions SUCK... for the simple reason that you Cannot delete an Extended partition without killing all of the logical's. Why would you want to delete it? Well, it happens... sometimes you need to delete and recreate partitions for whatever reason. it's a royal pain to have to move data off of partitions you DON'T WANT TO DELETE just to do it.
You can have 4 primary partitions per hard drive. Unless you get crazy with partitions, there should be no reason to use extended....
Whitedog
3,656
If that's what PartitionMagic thinks than PartitionMagic is retarded. An extended partition is Not a primary partition. Microsoft doesn't see them that way.
ozone13
498
Exactly. There is no reason to use extended unless you want more than 4 partitions per physical harddrive.
jjyiz28
2,901
i may be wrong, but can you NOT install your OS on a logical extended partition? something about not being able to make it the active partition during boot up
ChefJoe
2,506
I thought it was legacy stuff.
Dos only allowed 4 partitions per drive, you can use all 4 as primary or use a combination of primary and extended/logical drives. Primary partition is a bootable partition of the drive, extended allows for you to make a drive type that bypasses the limit of 4. The extended partition is just a space-marker (telling your os that new rules apply here) and it's the logical drives created in that partition that can go up to as many letters as the alphabet.
jjyiz28
2,901
i think using fdisk under DOS, it only allows 2 partitions per drive.
DannyBoy
8,820
www.danj.me
Thats funny because I have 5 partitions on my drive which were done in...oh wait....fdisk. ;)
ChefJoe
2,506
I think I've confused people, please read about extended partitions/logical drives being the dog's breakfast of partition types.
The partition table only allows 4 entries of primary and extended type partitions. The extended partition says "new rules, you can make more than 4 drives in here"... to use the extended partition, you need to create logical drives in that space.
My thought is that you can have setups like
4 primary
3 primary 1 extended (which only has useable drive space when you create the logical drives in it)
4 extended (with logical drives from A-Z distributed throughout the extended partition)
jjyiz28
2,901
you sure you're not running 1 primary and 1 extended, the extended split up into 4 logical drives?? that is still 2 partitions.
DannyBoy
8,820
www.danj.me
You didnt say 2 primary partitions, you said 2 partitions.
Yes Im running 5 logical partitions, 1 primary, 1 extended with 4 logical disks.
If you had said "i think using fdisk under DOS, it only allows 2 primary partitions per drive, I would of been curious myself because I dont know whether or not that is the case ;)
unbiased
380
wow,
what a place to contribute my two bits worth of curiocity.
This is the question which has kept me awake many a night.The million pesos question ,HOW DO YOU GO ABOUT CREATING MORE THAN ONE PRIMARY DRIVES,using Fdisk.I have tried it and it doesnot allow more than one PRIMARY drives.It allows many logical drives on an extended drive but not more than one PRIMRIES.
Second question is WHAT IS THE DIFFERENCE BETWEEN AN ACTIVE PARTITION AND A NORMAL ONE ? IS IT NECESSARY TO HAVE AN ACTIVE PARTITION BEFORE INSTALLING OS?
Any answers?
Pariah
7,357
20
You can only create one extended DOS partition. What would be the purpose of having more than one?
Fdisk only allows you to create 1 primary DOS partition.
You can't.
At least one primary partition must be set to active to designate the boot partition.
Whitedog
3,656
fdisk is sooooooo old school.... Use Disk Manager to create/delete/format your partitions. Even if it's to install a 9(su)X install. It's so superior it isn't even funny. You can specify cluster size with a "click" ;)
You are beyond confused DannyBoy. :p
1 primary + 1 extended with 4 logicals = 5 logical partitions?
:D
