- Oct 31, 1999
- 2,743
- 0
- 0
Originally posted by: GigaCluster
The difference is obviously the frequency on which they operate. I believe that 2.4 GHz, due to its shorter wavelength, can penetrate through more matter and therefore would sound clearer/stronger compared to the 900 MHz in the same situation.
Also, less appliances/devices use the 2.4 GHz frequency, so there's less interference.
Originally posted by: Lifer
I would have to say the difference is in just the frequency.
I've had both (panasonic models) and they're equally clear, and maybe the 2.4 goes a bit further.
but definitely go 900 mhz if you have wifi.
Originally posted by: NutBucket
Strangely enough our Panasonic 2.4Ghz phone interfers with the Logitech Wireless PS2 controller. I wonder what happens if I try to use bluetooth....
Originally posted by: Mallow
I think the distance it can travel is better. Also, 2.4ghz goes through walls better.
higher frequency you loose range
