shortylickens
Cuz no one seems to be able to give a clear answer.
i only wear seven jeans
Are they better than Diesel?
I don't know, but I do know that Levi and comfort in the same sentence is fucking pure blasphemy. Levi has never, and will probably never make a comfortable pair of jeans.
So, what do you consider comfortable?
Just go to the store and try them on, you friggin' hermit. You will find a 'style' of Levis that fits your preference and/or proportions.
And no one will know you're not wearing Diesel or Ed Hardly or what-the-shit-ever. If you really need to be cool, get a drill and make some holes.
Straight men wear Levi's. /thread
560 has a tapered leg and definitely more room in the thigh area. It's the only Levi jean I wear. I will say 560's used to have 7 belt loops, but a few years ago they went down to 5 which sucked.
I'd actually prefer 4 loops, at NW, NE, SE, and SW. That way I could put accessories and junk directly on my sides. My Note 2 case is huge.
I find the 560 personally for myself are more comfortable than any other Levi Jeans I can wear. I wear then exclusively to work.
