Originally posted by: Operandi
The Cu version isn't worth the added weight and cost in my opinion.
Originally posted by: danklumpp
I was thinking of getting an Ultra, and the Arctic Cooling wouldn't work on that anyway.
How much heavier is the copper version?
Read the reviews, you'll see that the Cu version cools a few degrees more than the AlCu version, so it definately is worth the extra cost which is only about $5. And weight really isn't an issue here, the copper is heavier, but its not that heavy at all to do any damage to the card.
Originally posted by: albumleaf
If you want your GPU heat expelled from the case immediately, get the silencer. Otherwise the Zalman will give slighly lower temps (at the expense of ambient case temp rising)
