N nickdakick Platinum Member Jun 27, 2000 2,484 0 0 Jan 31, 2001 #1 from the core of a Tbird ? I want to replace it with Artic Silver. Is nail polish remover OK ?
P Poof Diamond Member Jul 27, 2000 4,305 0 0 Jan 31, 2001 #2 Yep. Works great. You can finish up with some isopropyl (rubbing) alcohol as well...
Z ZeroBurn Platinum Member Jul 29, 2000 2,892 0 0 Jan 31, 2001 #3 nail polish remover works great. if it gets messy WD40 works well to clean most of it off.
M Miraluka Member Dec 19, 2000 161 0 0 Jan 31, 2001 #4 First wipe it off a little with something, then use rubbing alchohol to get the residue off. Otherwise you'll just smear it all over the place.
N nickdakick Platinum Member Jun 27, 2000 2,484 0 0 Feb 1, 2001 #5 Thanks everybody. I'll see if that will improve cooling.
