What's the best way to hook my new Creative Zen Micro to my car while preserving as much audio quality as possible?
NFS4
47
Just got a Zen Micro 6GB from BB for $199 - $50 instant GC, so I was wondering what's the best way to hook this up to my car while preserving as much audio quality as possible? FM transmitter?
My head unit
tweakmm
18,436
4
If your head unit doesn't have audio inputs then the best quality will be had from a tape adapter. A fair bit more bandwidth available with that versus the FM transmitter, it just sucks that it makes everything look so cluttered.
NFS4
47
Duh, just realized that my head unit is CD only. Guess that means Fm transmitter :(
mzkhadir
9,509
what about an aux input in the back of the cd
tweakmm
18,436
4
Yeah, I'm gonna make a crazy guess and say that the tape adapter is probably not your best option.
NFS4
47
Cha-Ching. That's right...I have an open bay below my head unit. Could run a wire under there.
I'll have to look into that :D
mzkhadir
9,509
my old aiwa used to have an aux input and I used my iriver cd player with that to play my wma files. With my new panasonic mp3/wma cd player, I dont have that option.
NFS4
47
Damnit, I don' have a diagram of what the back of my unit looks like. Guess I gotta go look in the garage for the box or crack open my dash again.
Twista
9,646
keep the receipt :/ mine broke and my sisters just broke =( Damn it we have to RMA them both in for service. Mine has the famous common earphone shortage problem and now its freezing up @ the intro part. My sisters just broke and its not freezing up @ the intro part also.
gl
OREOSpeedwagon
8,485
I agree with Twista. I had one 5gb micro die on me within 3 months of when i purchased it, then the one i exchanged it for died within 6 days. i then went iPod and haven't looked back :)
vshah
19,003
24
Well, looking at the instruction manual, it appears that my head unit has an auxillary input. So what kind of cable would I need to hook it up to my Zen?
would probably be just a standard 1/8" stereo audio cable to your zen's line out
ElFenix
102,397
8,564
miniplug on one end, whatever the aux input is on the other ;)
i'm guessing miniplug to miniplug
mzkhadir
9,509
you can get at bb ($6) or radioshack.
Most likely your head unit has 1/4" L/R jacks in the back.
So you would probably need a 1/8" headphone -> 1/4" L/R RCA cable, or adapter + cable.
NFS4
47
I was wrong I guess. Looks like there's an option for the aux in the menu system, but I don't see anything on the back of the unit. I see an input for the antenna and one for the CD changer. Nothing else :(
Page 26 of the manual listed above
tweakmm
18,436
4
There are CD changer adapters for I-pods, maybe there is one for the Zen.
mzkhadir
9,509
if you unit plays wma/mp3, why worry about the zen ?
NFS4
47
You can never have too much space ;)
That sucks, then your best bet is a FM adapter, or buy a new head unit.
fbrdphreak
17,555
I dunno if your Kenwood has 'em, but most headunits have a proprietary connector on the back (if any) and you need to buy their adapter. Only a few cheapo decks (that I know of) have direct RCA inputs.
I think Kenwood makes an adapter for their higher end units that converts the Kenwood plug to a mini-stereo, I know Alpine does. I doubt it for your "low end" unit, but call them and ask. That's your best bet
spacelord
2,127
I have tried 2 different FM modulators hoping to get decent sound in my stock radio which has no inputs or tape deck. Both are unacceptable. I have a Belkin and an iRiver one.. something like that. The frequency range just isn't there.
