whats the best way to get water stuck inside my ear out
BooGiMaN
7,955
its really annoying...
anyone know and easy way and painless way to get it out?
AgentEL
1,327
walk it off? If it persists you can go to urgent care and get an "ear lavage".
TheNinja
12,207
Whatever you do, if you are in a small airplane, do NOT jump up and down, you will cause and emergency landing and then get yourself and your 3 friends tossed in jail for a year.
Queasy
Moderator<br>Console Gaming
Aug 24, 2001
31,796
There are some drops you can buy. I can't remember the name right now though. My wife just bought some the other day.
TWControls
47
Spray water into them. Sounds crazy but getting water in your ears is normal. When it won't come out of mine it is usually a sign of wax. I let water out of the shower head spray in it and it flushes the wax out
Beev
7,775
I always just shake my head like the night at the roxbery guys. Works everytime for me.
2Xtreme21
7,044
Lay on your side that has the clogged ear. Sometimes if you do so on a warm towel or otherwise warm object I find it will ease it out faster.
Or you can get those swimmers' ear drops. Those thing hurt like a mofo and it feels like your inner ear is on fire for about 2 minutes, but it does the trick.
kt
6,032
1,348
Seriously, just tilt your head to one side then jump up and down. The water is stuck in your ear because of beading, so the jumping will break the water bead and comes out. When it comes out, you'll feel a warm sensation.
doze
2,786
You can spend 5 on a bottle of drops or just use a little rubbing alchohol in the ear. Search for swimmers ear and you will find more info.
imported_goku
7,613
Go into the shower, let water drain into your ear, tilt 180 degrees and let it drain out with out getting water into your OTHER ear.
Synth3t1c
293
drop alcohol in your ear, or just like (for right ear) move your head to the right real fast then pull it back... i ususally do the latter and it works
amicold
2,656
Ruining your NBC sitcom run, and causing you to never make it big.
IMaN00BieGF
469
momsmad
41
this sounds weird but I always got water in my ears. I would tilt my head to the side with the water in it,downward and jump up and down. in a minute or so you will feel it coming out. you could also try sweet oil. comes from drug stores.
zanieladie
3,280
Use some rubbing alcohol...that's all that is in the over-the-counter stuff that you can buy. For example, I looked at the ingredients of "Swim Ear" (used to remove water from the ears) and it had alcohol and glycerin in it. That's all. Besides, a bottle of rubbing alcohol is MUCH cheaper!
Oct 4, 2004
10,515
1) Play "What is Love by Haddaway"
2) Pretend you are Chris Kattan from "One Night at the Roxbury"
Would a hair dryer (at full-blast) pointed at your ear work?
