3DVagabond
- Aug 10, 2009
- 11,951
- 204
- 106
What is a reasonable framerate for the games? I mean a framerate where you can nicely without any lag or freezeups.
If I have a monitor with 1080p resolution and I lower it to 1680x1050, will the picture quality get reaaally bad or would it still be reasonable?
Also when comparing the stock gtx460 to the hd6850, there's very little difference in terms of framerate, only 3-4frames. Some games, gtx460 is slightly better, and in others hd6850 by a few fps. So is 5 frames a big difference?
Also I had read that some cards like the 6000 series are better at tesselation. Is this included in the 4AA(anti-aliasing) test in the charts at anandtech GPU benchmark tests?
http://www.anandtech.com/bench/Product/313?vs=291
Or is it safe to say that these cards are almost the same, and one should just get the cheaper card one can get?
Yes, virtually no difference between the 2. Just watch what you are buying if you go with the 460. There are the 460se cards that are slower, further crippled chips, and there's also the 460 768MB with less RAM. People throw pricing around on these cards like they are talking about one card. "You can get a 460 for $100 and it's $150 for the 6850", type of talk. The cheapest 460's aren't comparable with the 6850.
