Whats the best 5.1 speakers with a remote control?
Rhodent
666
I have the Cambridge DTT 2500. It is irritating that I can't change the volume by remote control. What is the best comparable set of speakers I can get that does have a remote control unit on them?
jcmkk
1,159
If you are talking about a wireless remote, then it is gonna be pretty hard to find. I would suggest that you get a Audigy Platinum instead since they come with a remote that you can use for volume.
Rhodent
666
I have the SOun Blaster Live 5.1 with Live Drive right now. I also have the DTT 2500 series Speakers. The 3500's used to have the remote control. But point is. This remote wont work that volume when playing DVD's through my H+ decoder card because its not an amplified signal. The dvd signal goes directly from the card to the speakers in digital un amplified format. I need a set of speakers that can be adjusted independently no matter what signal is going into them. I saw on the Creative site that the Inspire 5.1 5700 series has a remote but it doesn't say if its wireless or not. But it shows a little picture. Anyone else have any input on this matter?
jcmkk
1,159
I wasn't talking about the Live! Drive. It has a wireless remote. As you were saying though, the top of the line Creative speakers do come with a remote.
Lore
3,624
I'd like to see what other options there are in terms of high quality 5.1 speakers as well. I've been using the DTT2500 for two years now and while I don't really need an upgrade, I always keep my eyes open for something that might be better.
jcmkk
1,159
Lore - If you have the money, the Klipsch Pro Media 5.1's are awesome. There are no other speakers that can match them in my opinion. I don't have them though, but I do have the Logitech z560s. If you can deal with just 4.1 surround, then the Logitechs are impossible to beat for the price.
