What's the benefit of using a rice cooker over just using a boiling pot of water??
aphex
Moderator<br>All Things Apple
Moderator
Jul 19, 2001
38,572
My wife and I usually just boil some water and throw the rice in for 20-25 minutes. What's the benefit of going to a rice cooker?
Also, I never realized you were supposed to wash rice before cooking it. Is this common knowledge or something?
purbeast0
53,634
6,508
i cook my rice a lot different than most people do, and using a rice cooker wouldn't work for the way i cook it.
Ramma2
2,710
I've been contemplating getting a small 3 cup one to keep here at work, so I can eat fresh rice at lunch.
Bout 25$ on Amazon.
Gibson486
18,378
you can time it and everything if you get a good rice cooker.
Cleaning rice is pretty common knowledge. However, I have seen people not clean it. Maybe uncle bens does not need to be cleaned. I have no idea.
MiniDoom
5,305
Originally posted by: Capt Caveman
Do a search, there are a number of lengthy threads covering this subject.
what is this "search function" you speak of? :p
Arkitech
8,356
4
How do you cook it?
ElFenix
102,402
8,572
iirc, you should simmer rice, not boil it. simmer is just below a boil. somewhere around 200 degrees.
Descartes
13,968
It's just easier, imo. It keeps it hot and fresh during dinner and for an extended period thereafter.
We always clean ours, but we buy them in the big bags that you get as international markets. All kinds of interesting things can find their way into these bags. I don't think you need to wash rice that comes from a sealed container, but I could be mistaken.
torpid
11,631
11
The benefit is you just plop the ingredients in, then you have plenty of time to use the search function on ATOT.
purbeast0
53,634
6,508
how is that?
first i put some onions in the pot sliced up and some oil (like to coat the bottom) and i let the onions get soft and heat up.
then i put in the rice and i constantly stir it up while it is heating the rice all over for about 5-10 minutes till al lthe rice is slightly covered in oil and it is starting to brown slightly from the heat.
then i add in the water and keep the top off till it boils, then i put the top on it till the water has all steamed out.
i only use jasmine or long grain brown rice, but for brown rice i need to put water in like 3 times.
my (now) fiancee taught me this when i first met her and i have never cooked rice differently since. it tastes so much better than just steaming rice. i do not even like normal steamed rice because its so damn plain tasting.
and i think there is a name for cooking rice this way but im not sure what it is.
ghostman
1,819
I believe rice used to be covered in talc powder, so people wash it off. I believe they use starch or something nowadays that don't need to be washed first, though some people still do.
I've always used a rice cooker. With the new cookers, it never burns and it never sticks. Plus, we eat rice at least once every day.
krunchykrome
13,413
how is that?
sounds like you need your own cooking show :p
Perknose
Forum Director
10,651
147
Re: washing your rice first.
Over the years I have heard many different takes on this;
Some say you shouldn't wash your rice at all since it washes away many of the nutrients.
Others say you should simply let it sit covered in water first for a brief time, then pour the water off, and repeat this up to a total of three times.
Still others say you should turn a high pressure fire hose on those dirty little grains, and take no prisioners, 'cause there's cooties in there. :p
I've also been taught in the past that "light roasting of your rice" before you add water and boil it method, though the "onions first" part is a new wrinkle to me. Sounds good, though.
purbeast0
53,634
6,508
how is that?
it's a lot easier than it sounds and tastes SSSSSOOOOOO much better. it's just the way that her family has always cooked rice, and i've been to a ton of nicaraguan dinners and stuff w/her family (and over in nicaragua too) and that's just how they do it.
