artifact test sucks like crazy. it only tests dx7. Which means some features of the card go unused. on my radeon 9000 pro, artifact tester detected no artifacts at 350mhz core. So i kept it there, i went into c&c generals 2 seconds later artifacts like crazy. I go into 3dmark 01 artifacts as soon as it gets to nature test, then 3dmark o3, artifacts in second game. So you must test the dx version your card uses and you must test all of it's features at an oc before you say it is stable. my gpu is only stable at 320mhz core, not 350 like artifact tester said. the best way to test for stability is 3dmakr 01 looped then 03.
