Originally posted by: BD2003
As it stands I still find it pretty hard to recommend WHS to people over buying a 1TB external HDD for ~$100, sharing it across the network and setting windows backup to run every night. Right now, it really doesnt do much more than that.
Well, there's a HUGE difference between a Windows backup (at least the XP version) and what WHS provides.
I have a WHS box at a client with eleven PCs. The office manager decided that they'd skip backups on one of the PCs and asked me to make an NTBackup of that box and store the .BKF file on their WHS.
Six months ago, Windows got trashed on one of the WHS clients. Over the phone, I told them how to restore it. It took about five minutes of work and about an hour of restore time.
Two days ago, the one PC with the NTBackup needed to be restored. They had to re-install Windows, update it to SP2, and then run an NTBackup restore. I don't know if they are done yet, but it'd take an hour or two of labor and several hours of restore and update time. Downtime on the PC would be most of a day.
And I agree with you, but I've bolded the relevant part.
This is supposed to be windows home server, not windows small business server. As it is right now, its certainly justifiable for a small business to use WHS, and its great for that purpose. But it doesnt do enough for the home with 1-3 PCs to justify it's cost.
WHS is good, but its not good enough. It can stream media to other PCs, but any Windows PC can do that with WMP. It can host files on the network for all...but so can any PC. Remote access is built in to all PCs. The backup in WHS is great, but backup isnt anything new either.
When I'm thinking of what a home server, I'm thinking much bigger. It should be the centerpiece of home computing, not a cute little file server backup box. It seems crazy the way it is to me now, where you get a warning if you even try to log into the thing, as if using it for anything but file sharing and backup is out of the question.
I shouldnt need a wireless router - the server should be/contain the router. This way it should be able to monitor all incoming traffic and provide firewall and antivirus duties for the entire network, so I can take that burden off the individual PCs.
I should be able to run thin client terminals into every room in the house, where anyone can log on to any PC/Terminal and get the exact same desktop up and running just as they left it, because the server is doing the real processing.
I should be able to throw two tuners into it and have it handle everything media center is doing, and let an XBox 360 do the rest.
It's always connected to the internet, so I should be able to take a netbook with me and access my files from the coffee shop without having to think about syncing or going through some silly web interface.
It should not only be able to duplicate across drives, but sync to the cloud for documents and pictures, and other small, precious data.
I think right now its totally backwards - atoms are going in the servers to handle clients with quad cores. The quad core should be in the server, the atoms should be in the clients.
Granted, this would take an entire rethinking of the home computing environment, but that would be what I'd call added value. I'd like to be able to order a network from HP, complete with server, desktop thin client and netbook, all made to work perfectly with each other out of the box. That would be badass.
