What's my PCI bus speed & will it affect a scsi card at 160fsb?
blackhawk
2,690
Have an Epox 8k7a running at 160fsb and wonder if it would give a scsi card problems as I'd like to get a scsi cdrw. How about my agp vid card? As I've been tweaking things a bit I'm noticing the vid card is running a lot hotter. Its an asus 6800 with a blorb on it and I've been thinking of switching it with my V 5500. Which vid would handle the the higher agp better?
Boonesmi
14,448
pci is meant to run at 33mhz it runs at 1/4th the fsb. 133 divided by 4 = 33mhz
if you run your fsb at 160 then your pci is running at 40mhz. and yes this could cause problems with a scsi card, some pci cards can handle highly overclocked busses and some cant. no telling until you try it with that particular card
mastertech01
Moderator Emeritus Elite Member
Nov 13, 1999
11,875
282
Adaptec cards handle high fsb pretty well but that is really pushing it and leaves you at high risk for errors IMHO
